LoriWhitwam
Jul 24, 2016Aspirant
N300 EX2700 won't connect with modem
Trying to install N300 EX2700 range extender, but the device link LED never lights, not connecting with modem. I even have it hooked up with ethernet cables right now, and it still won't connect. Any...
- Aug 02, 2016
No, it didn't. But a couple days later, a wi-fi network "Netgear_ext" showed up in my listings. I started messing with it, then I was able to access the activation webpage. I'm still not sure how I did it, but eventually it worked, and it's now set up and solved my lack of signal strength on the TV furthest from the router.
TheEther
Jul 24, 2016Guru
Per the FAQ in the manual (link), you cannot connect the EX2700 to a router or modem via Ethernet. IOW, you cannot use the EX2700 as an Access Point. It must be used as wireless range extender.
- LoriWhitwamJul 24, 2016Aspirant
That's what I'm trying to do. But I can't get it to recognize my wi-fi router to connect into the network. The power light comes on but the device link LED never lights up. They won't link. So I tried connecting them with a cable, just till it "met" the network, but that didn't work either. I think my router must have some setting that's preventing it (Linksys) but I don't know how/where to access the settings or which one might need to be changed.
- TheEtherJul 24, 2016Guru
I suggest you use a paperclip and perform a factory reset (push the button for at least seven seconds). Then follow the instructions in the manual to set it up.
On the router or the Netgear signal extender? (Sorry for being such a dolt...I have someone who usually does this stuff for me, but he's unavailable.)
