LoriWhitwam
Jul 24, 2016Aspirant
N300 EX2700 won't connect with modem
Trying to install N300 EX2700 range extender, but the device link LED never lights, not connecting with modem. I even have it hooked up with ethernet cables right now, and it still won't connect. Any...
- Aug 02, 2016
No, it didn't. But a couple days later, a wi-fi network "Netgear_ext" showed up in my listings. I started messing with it, then I was able to access the activation webpage. I'm still not sure how I did it, but eventually it worked, and it's now set up and solved my lack of signal strength on the TV furthest from the router.
DarrenM
Aug 02, 2016Sr. NETGEAR Moderator
Hello LoriWhitwam
Did the factory reset fix the issue?
DarrenM
LoriWhitwam
Aug 02, 2016Aspirant
