isthisbrian
Apr 30, 2017Follower
N300 EX2700 won't connect with new modem/router
New residence. Our Extender is still paired with old router. Since moving, I can't locate the manual. Is there an easy run down on pairing with a new modem/router?
Thanks in advance.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello isthibrian
Yes you will need to factory reset the unit by holding the reset button for 10 seconds then set it up again.
DarrenM
