darkmatter661
Mar 13, 2017Aspirant
N300 Extender does not see Sonicwall TZ300
I have a Sonicwall TZ300 with internet working fine in 2.4Ghz in n/g/b mixed mode. I'm trying to extend it with an N300 which used to work just fine on a TZ100. However, the N300 does not see the S...
DarrenM
Mar 15, 2017Sr. NETGEAR Moderator
Hello darkmatter661
Is the new router a 5ghz signal? the n300 is 2.4ghz only.
DarrenM
darkmatter661
Mar 15, 2017Aspirant
It's 2.4Ghz.
- DarrenMMar 16, 2017Sr. NETGEAR Moderator
Hello darkmatter661
Have you tried to factory reset the extender and try setup again?
DarrenM
- darkmatter661Mar 16, 2017Aspirant
Yes, several times. I default it with the reset button and try it again. It never sees the AP, but PCs and laptops equipped with wireless do.
- darkmatter661Mar 20, 2017Aspirant
Any other suggestions??
