darkmatter661
Mar 13, 2017Aspirant
N300 Extender does not see Sonicwall TZ300
I have a Sonicwall TZ300 with internet working fine in 2.4Ghz in n/g/b mixed mode. I'm trying to extend it with an N300 which used to work just fine on a TZ100. However, the N300 does not see the S...
darkmatter661
Mar 15, 2017Aspirant
It's 2.4Ghz.
DarrenM
Mar 16, 2017Sr. NETGEAR Moderator
Hello darkmatter661
Have you tried to factory reset the extender and try setup again?
DarrenM
- darkmatter661Mar 16, 2017Aspirant
Yes, several times. I default it with the reset button and try it again. It never sees the AP, but PCs and laptops equipped with wireless do.
- darkmatter661Mar 20, 2017Aspirant
Any other suggestions??
- DarrenMMar 24, 2017Sr. NETGEAR Moderator
Hello darkmatter661
Are you able to use the WPS method to connect the extender?
DarrenM
