richardcordrey's avatar
Sep 19, 2018
N300 Wifi extender
Hi, This extender has worked fine for two weeks but now will not connect to web pages. All four lights on display are green saying it is connected to my device and main router tncap -ext has a tick next to it saying its connected but web pages won't load. Thanks
  • StephenB's avatar
    What device is this? Also, what router are you using?
    Have you tried powercycling the extender?
    • richardcordrey's avatar
      richardcordrey
      Good afternoon. Thanks for your time.
      It is model WN3000RPv3.
      It worked fine for two weeks but now internet doesn't work even though all indicators say it,s  connected including client light which is lit green.
      • StephenB's avatar
        When you said the extender was connected to "my device", what device did you mean?
