dom73
Aug 07, 2017Aspirant
N300 WiFi Range Extender Model EX2700
OK, So, I purchased the N300 WiFi Range Extender Model EX2700. I followed the instructions, and all the lights on the extender are showing the right colour. I can see the extended newtork on my laptop, and on my phone, however, I cannot connect to it as I have no idea what the password is! On page 8 of the manual, it states, The extender creates a new extended WiFi network. The extenders new WiFi network name is based on your existing WiFi network name with _EXT at the end of the name.
I can confirm that it has done this.
It then states - Use the same WiFi password that you use for your WiFi router.
This is not the case, as it just won't accept the current password.
I can't even get to mywifiext.net. I just get an error message saying the page cannot be found, which I guess means that it's connecting via the existing network router.
Do I need to reset the extender, or do I need to purchase an ethernet cable and connect to the extender that way? I only bought the extender so that our new TV could connect - Help would be appreciated
- DarrenMSr. NETGEAR Moderator
Hello dom73
I would try to connect via ethernet get back to the settings and try to change the password.
DarrenM
- SmartyukAspirant
Hi Dom73
Did you ever manage to get this sorted? I have almost the same problem. I have connected to my wifi but I want to connect my tablet, when I click on my ext it ask for my password but It does not accept it. So here I am very frustrated I cannot connect my tablet. Can anyone help with this for me please? Thank you
Try removing the network from the tablet in the tablets wifi settings then try connecting again.
DarrenM
