pferaboli's avatar
pferaboli
N300 WiFi Range Extender Model WN300RPv3 troubleshooting with dlink router
Hello to all,
i have a N300 WiFi Range Extender Model WN300RPv3.
I installed and worked. Only if just want going in the setting of my web router, D-Link DIR-655 Xtreme, and particularly in the Wireless setting, I realized that I can not 'access anymore. If I try to enter the Wireless setting it redirects me to a web window at /welcome.htm. I try turning off the Extender, reset it and turned off, router, reset my Dlink router. Nothing changed in my Dlink router. How can have my router back?
Thanks
  • Thanks to all for your cooperation but I resolved. Everything 'success during setup the extender. Before ending I agreed to the request to make a bookmark in my browser. After that if I entered 192.168.0.1; Setup - Wirelss I was redirected to www.mywifiext.net//welcome.htm. Then I noticed that if I was using microsoft edge this did not happen. So I with the help of the Firefox extension nodirect I solved the problem. I hope that can help other people.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello pferaboli
    Are you trying to get into the settings with a ip address like 192.168.1.1 or is it like a normal link with D-Link?
    DarrenM
    • pferaboli's avatar
      pferaboli
