StuartJ12
May 18, 2016Follower
N300 WiFi Range Extender not working with Windstream
Windstream said I needed an extender for computer in basement. I just got a N300 and followed the installation instructions but the Router Link LED never comes on even if I put the extender in the s...
DexterJB
May 24, 2016NETGEAR Moderator
Hi StuartJ12,
You will need to go through the setup procedure.
You may check the quick start guide linked below as reference.
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_QSG_17Aug2015.pdf
Dexter
Community Team
Subramanianmca
Jul 01, 2016Aspirant
Hi,
Did you get this problem resolved?
I have the same problem with my wifi extender. Couldn't fix it. Can anyone help to fix this problem?
My router was working fine for 20 days and stopped working after that. There is no special cause I could figure out...
Your help is highly appreciated... Thanks in advance
Subbu
- DarrenMJul 07, 2016Sr. NETGEAR Moderator
Hello Subramanianmca
Have you tried to factory reset the extender and do the setup again?
DarrenM
