StuartJ12
May 18, 2016Follower
N300 WiFi Range Extender not working with Windstream
Windstream said I needed an extender for computer in basement. I just got a N300 and followed the installation instructions but the Router Link LED never comes on even if I put the extender in the s...
Subramanianmca
Jul 01, 2016Aspirant
Hi,
Did you get this problem resolved?
I have the same problem with my wifi extender. Couldn't fix it. Can anyone help to fix this problem?
My router was working fine for 20 days and stopped working after that. There is no special cause I could figure out...
Your help is highly appreciated... Thanks in advance
Subbu
DarrenM
Jul 07, 2016Sr. NETGEAR Moderator
Hello Subramanianmca
Have you tried to factory reset the extender and do the setup again?
DarrenM
