pseudosu's avatar
pseudosu
N300 will only allow one computer to connect at a time (?)
Hello,
I have an old dsl line with a static IP address.  I was using a mac time machine until it fried and just picked up my Netgear router  (WNR2000-- N300 WiFi router) yesterday.  After doing the manual set-up necessary because of my static IP sitch, it will only allow me to connect one computer at a time.  In a multiple puter household this is obvs not acceptable.  Anyone have any solutions?  Please explain at a very remedial level.  Thanks in advance.
  • What is the setting of IP address range on the LAN set up page? Yout set up should be
    like 192.168.1.2 - 192.168.1.254 or leave it at default.
    • pseudosu's avatar
      pseudosu
      The IP begins with 208...  Is that what you are referring to?
      • VE6CGX's avatar
        VE6CGX
        Master
        Range has beginning address and ending address. Every device needs an ip address handed out by DHCP. So what is the range?
        You have one address, 208? That's  it?
