afenn
Sep 28, 2017Aspirant
N600 range extender - Model WN2500RPv2 -- Troubleshooting
An older range extender which no longer allows me to connect to it. First step, reset to factory settings. Pressed the button on the back and now the WIFI networks reads: "NETGEAR_EXT" I sel...
DarrenM
Oct 02, 2017Sr. NETGEAR Moderator
DId you try to use multiple web browsers?
DarrenM
afenn
Oct 02, 2017Aspirant
That box is auto generated whenever you select the network "netgear_ext".
It isn't a web browser. Any attempt to use a web browser fails for it will say there is no internet connection.
- DarrenMOct 03, 2017Sr. NETGEAR Moderator
Have you tried the extender setup on a phone or tablet and see if you get the same results?
DarrenM
- afennOct 09, 2017Aspirant
I've tried with a tablet and receive the same results. When the network is selected a blank box pops up, unable to login or select anything.
