Zaradi's avatar
Zaradi
N600 range extender set up on a mac
I had this all set up to work with the Amazon firestick once...had to make some changes and now i cant get it set up again.  I have a modem hooked to an Apple airport express via Ethernet (WAN) with everything else running wireless.  Which of the 3 ways do I use?  Can't use the WPS way as the Airport has no button.  I suspect i have to use the ehternet cable way.  So is this correct?....ethernet to router AND another ethernet cable from the computer to the extender?  I'm really confused and I know I didn't have this much trouble the first time....any help would be appreciated.  The directions don't seem to be Mac friendly.  Thanks
1 Reply
  • nhann's avatar
    nhann
    NETGEAR Employee Retired
    Hi Zaradi,
    Can you please confirm which modem you are using and which N600 Range Extender model you have?
    Thank you
