DGehman
Dec 02, 2022Tutor
Need procedure to connect Linksys E2500 > EX5000 extender
My Linksys E2500 dual band won't connect with the Netgear EX5000 extender using WPS. I've enabled WPS in the Linksys and it uses WPA/WPA2 security. The Linksys won't connect to the extender either w...
- Dec 03, 2022
They don't require new passwords. But I would try changing the ssid/password.
Avoid using special characters or spaces as some (poorly coded ) devices have issues with those
Dec 03, 2022Guru - Experienced User
DGehman
Dec 03, 2022Tutor
plemans, many thanks for your help.
We are now up and running. Our far bedroom Amazon Echos are seeing a very strong wifi signal, where before, we were getting dropouts with a touch of off-into-the-ether.
My situation was not normal because the engineering workstation that's my main computer does not have wifi and thus no way to find or connect to the extender's built-in local network NETGEAR_EXT. The workstation connects to the wifi router via Ethernet and the NETGEAR_EXT didn't show in any understanding place on the router's dashboard.
Very much appreciated.
