KABL
Jun 21, 2017Tutor
Need to change settings and factory reset is not working
Hi, I have an EX6100 extender. We changed the WEP password on our router and now can’t get throughput on the 6100. When I do a factory reset it doesn’t work--the old network names (for 2G and 5G) sti...
KABL
Jun 21, 2017Tutor
Hi, I have the manual and have followed all of the instructions. I have reset several times, I have "forgotten" the old networks, etc. nothing is working.
- netwrksJun 21, 2017Master
Did you change the SSID names and a factory reset isn't clearing it? Or, do you see the Netgear_ext SSID's?
- KABLJun 21, 2017Tutor
I think both. I see the old Netgear_ext SSID's, and the factory reset isn't clearing them. Problem started when I changed the WEP password on the router. I can't seem to access the device online to change settings, so am looking to reset and start with new Network SSID's and passwords.
The Netgear SSID's are the default SSID's.. The extender box that it came with, would tell you exactly what the default SSID's are. Take the extender off the network and run the Smart setup - Page 16 - 17.
