KABL
Jun 21, 2017Tutor
Need to change settings and factory reset is not working
Hi, I have an EX6100 extender. We changed the WEP password on our router and now can’t get throughput on the 6100. When I do a factory reset it doesn’t work--the old network names (for 2G and 5G) sti...
netwrks
Jun 21, 2017Master
Did you change the SSID names and a factory reset isn't clearing it? Or, do you see the Netgear_ext SSID's?
KABL
Jun 21, 2017Tutor
I think both. I see the old Netgear_ext SSID's, and the factory reset isn't clearing them. Problem started when I changed the WEP password on the router. I can't seem to access the device online to change settings, so am looking to reset and start with new Network SSID's and passwords.
- netwrksJun 21, 2017Master
The Netgear SSID's are the default SSID's.. The extender box that it came with, would tell you exactly what the default SSID's are. Take the extender off the network and run the Smart setup - Page 16 - 17.
- KABLJun 21, 2017Tutor
Thanks for helping! I don't have the box as the item is a year old. When I try to find the network, all I have available are the old network names, and I can't access them because the password no longer works. Therefore I'm not able to get to the mywifi.net site to make any changes. After a factory reset, the defaul networks should appear in my network options, but they don't.
- cropieSep 17, 2017Initiate
I'm having the same issue. I moved and have a new internet service provider. I've tried using factory reset many times, but it doesn't work, the old extender networks associated with my old internet still show up, not the defaults.
