dazlam
Dec 05, 2016Tutor
NETGEAR EX3700-100UKS AC750 Mbps Using the Ethernet Port to send signal into Powerline
I am contemplating buying the above. I have a router in a small room at one end of the house and I'd like to pick up the signal from this router with the repeater below; https://www.amazon.co.u...
- Dec 05, 2016
If you already have powerline devices that you can use with Ethernet, consider buying a router / extneder that supports Access Point mode. Avoid extending your wifi signal from a base router.
netwrks
Dec 05, 2016Master
- dazlamDec 05, 2016Tutor
So I need to find an extender, as opposed to the unit above, and make sure it supports Access Point mode. So is this something that does a similar thing, i.e. pick up the exisiting wifi signal and extends it? As all I need to do is pick up the wifi signal from my main router (where the internet feed comes into the house) and get it to another plug socket location so that I can get the powerline set up onto the right electric circuit in the house.
- netwrksDec 05, 2016Master
It would something like this:
ISP modem / router modem combo<----->router<-------->Ethernett_to_powerline<------>other_end_of_powerline<---->ethernet connection_to_device that_supports_Access_Point_mode (router in AP mode or an extender that can be configured as an Access Point)
A device in Access Point mode is a layer 2 device that is connected via Ethernet, to extend your LAN segment. Not to be confused with wireless wifi extending. The Access point connects to your Base router via an Ethernet connection which is a consderably more stable connection to your Base router. The wireless client would connect to the Access Point and the data would traverse the ethernet connection between your Base Router and Access Point to get data to and from your wireless clients. Bottom line, a more stable wireless connection from clients connecting to your Access Point. Hope this makes sense..
Ah, I need it to go the other way, so need wifi from the router/modem to get me to an electric socket that is not in part of the extention of the house (different electric circuit). So I can start my powerline part of the network on a socket in the house. Like below;
Router/Modem (from ISP) <--------wifi signal-------->Extender<-------ethernet cable------>devolo plug unit<-------signal over powerline------>devolo plug unit in another room to broadcast wifi elsewhere.
Sorry, probably my fault for not explaining well.
I know a little but not a lot when it comes to this networking lark!
Thank you for your message btw :)
