dazlam's avatar
dazlam
Tutor
Dec 05, 2016
NETGEAR EX3700-100UKS AC750 Mbps Using the Ethernet Port to send signal into Powerline
I am contemplating buying the above. I have a router in a small room at one end of the house and I'd like to pick up the signal from this router with the repeater below;    https://www.amazon.co.u...
  • netwrks's avatar
    Dec 05, 2016
    If you already have powerline devices that you can use with Ethernet, consider buying a router / extneder that supports Access Point mode. Avoid extending your wifi signal from a base router.
