dazlam
Dec 05, 2016Tutor
NETGEAR EX3700-100UKS AC750 Mbps Using the Ethernet Port to send signal into Powerline
I am contemplating buying the above. I have a router in a small room at one end of the house and I'd like to pick up the signal from this router with the repeater below; https://www.amazon.co.u...
- Dec 05, 2016
If you already have powerline devices that you can use with Ethernet, consider buying a router / extneder that supports Access Point mode. Avoid extending your wifi signal from a base router.
rbscycle
Dec 08, 2016Aspirant
I bought an AC750 EX6100 Range Extender/Access Point, to extend my weak signal to the front bedroom. I ended up buying a LinkSys WRT54GL Router and used it as my access point instead of the EX6100, and it was cheaper!
dazlam
Dec 09, 2016Tutor
Thanks for your reply rbscycle. I have already bought the Netgear one now. Gonna set it up this weekend. Wish me luck!
Plug and Play? Hahahahaha!!
