Dennisedm
Sep 21, 2016Follower
netgear ex6100 extender
irecently tried to set up my extender (that was sitting on a shelf for over a year). i got everything connected correctly, and my computer can connect to its signal with out a problem. The only pr...
DarrenM
Sep 22, 2016Sr. NETGEAR Moderator
Hello Dennisedm
I would suggest trying to factory reset the extender and do the setup again. You can factory reset the extender by holding down the reset button on the device for 10 seconds.
DarrenM
