Gambit117's avatar
Gambit117
Follower
Oct 11, 2024
Netgear EX6150v2 Not Connecting to TMobile TMO-G4AR Router
Hello all,
I am having issues setting up my Netgear EX6150v2 on my TMobile WiFi network using a TMO-G4AR router. Since I don't have a WPS button on my router, I started setting it up as instructed in extender mode through the Netgear installation assistant. I'm able to get all the way to the final steps of connecting my devices to the newly created extension networks, but I always get a "Could not connect the extender to the existing network" message, and the Router LED link never turns on. I'm not sure what's causing the hangup. I am 100% certain that I used the correct password for the existing network, and I have attempted a factory reset and reconnect to no success. Does anyone know if this is a user error, extender problem, or if my router is not compatible with this device?
Thanks for the help,
No RepliesBe the first to reply
