retddon
May 30, 2022Initiate
netgear extender ex6120
I have a NETGEAR EX6120 extender connected to my Verizon 5g router. I can connect all devices thru the extender to the internet
with no issues (including 2 iPads) except my iPhone 13 and iPhone 12. The extender shows that the iPhone are connected (green light on) but no internet. Any ideas?
Thanks
Don
are you using icloud relay or private mac/ip address on them?
Try it with those disabled.
did you setup the extender using wps or using the installation assistant?
What verizon router is it?
- retddonInitiate
Thank you for the information. I turned off the private wi-fi address setting for only the Wi-Fi extender and now it works perfectly.
Thanks again for the assistance. Just a note that on my ipads that setting is turned on and the extender works.
Don
