mihailosundic's avatar
Feb 19, 2020
NetGear Extender EX7000 very slow download speed 40x slowdown
Hello, I would like to ask if anyone had an issue with extender and if you know how to fix it.
I have a speed issue with my EX7000 range extender.
Main router has speeds D/L = 52 Mbit DL and 8.38 Mbit upload
NetGear EX7000 DL speed is only 1.7 Mbps!!! Upload is almost the same as main router ~8.2 Mbps.
So comparing download from 52 Mbps DL to 1.7 Mbps it's almost 30x lower speed.
I am just setting it up out of the box, that means I'm right next to my main router, like 50cm from it,
also tried to set up FastLane from 2.4 to 5 Ghz but only got 1.95 Mbps!
I really tried everything that crossed my mind, I was switching through a lot of different channels,
did an update to FW so I also have the latest firmware V1.0.1.84_1.0.148
It is impossible that it's such a limitation, there must be something wrong with the extender.
I would expect it to be like 20 or even 10 Mbps, but 1.7 Mbps is practically unusable.
I just borrowed a cheap other extender worth 20$ from my neighbour and got great results,
it's impossible that I get 1.7 Mbps DL in the same room from the device that costs 130$.
I attached the picture
Please help!
  • I actually had bought it with older firmware and when it was not performing well I updated it to the latest, I don't think that two firmwares are bad for the device, than it's negligence and mostly anyone would complain for EX7000 to be not operational.
    Actually I managed to get it working, in a way... but only on one channel, I actually put it in fast lane but the opposite of what I've been doing, it works in 5 Ghz mode from Main Router to EX, and in 2.4 Ghz from EX to other devices.
    It isn't quite what I wanted because I wanted 2.4 between my MR and EX where I would have 3 walls and 30ft between, and
    5 Ghz between EX and clients since these are in the same room and room next to it (1 wall). I guess I'll have to settle with this setup.
    Now it shows speeds of 16 Mbps DL (out of 52 Mbps on my MR) and 8 Mbps upload (same as MR speed). It's still in the same
    room as the MR, so I guess a little slowdown when I move it to the other room, but I guess it's much better than 1.7 Mbps.
    Still not quite what I expected but let's say it is usable now, not really in value of 130$ IMHO, but what can I do now,
    I don't really see how to make it work right at the moment.
    Maybe someone would find this helpful too, it's a lot of trial and error, I'm not here to spit on the product, I bought it because
    I think it's the best in class but some pieces seem to have bugs or compatibility issues in work with non NetGeat routers.
    Will come back to leave my thoughts after I use it for a few weeks to see how consistent it is.
    Thanks,
    Mihailo
  • plemans's avatar
    Here's the steps I'd take.
    1. Factory reset and re-install using the smart connection wizard.
    2. Try re-installing the firmware. Potentially the firmware could have been corrupt. A reset only removes settings, a re-install overwrites the firmware. So re-install it, factory reset it, and re-install it.
    You also can potentially downgrade the firmware a version. Maybe your device has a bug with your firmware.
    I'd also move it a little further away. in the same room but 6-10ft away.
    • mihailosundic's avatar
      mihailosundic
      Thanks,
      Mihailo
