vensan's avatar
vensan
Follower
Oct 16, 2018
Netgear Genie not detecting WiFi
Netgear Genie not detecting WiFi. Hence not able to use it. Not sure how to trouble shoot it.
In my Router config, SSID is enabled.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi vensan,
    Welcome to the community!
    1. What is the firmware version of the extender?
    2. Can the extender detect other wireless networks (neighbors)?
    3. Have you tried changing the wireless channel of the router?
    4. Have you tried using another device for the setup?
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi vensan,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
