mufcboy234's avatar
mufcboy234
Netgear N300 connection timeout
I've had this for a while now it's been really good but recently while trying to play games online on the PS4 the connection is good but in game the ping is 15-25 but it rises to 200-400 then lowers then rises again it's never happened before I've moved it around reset it but it still happens.
  • StephenB's avatar
    Aug 14, 2018
    mufcboy234 wrote:
    It rises.
    Then the next troubleshooting step is to sort out whether this is internet congestion or an issue with the WiFi/extender throughput.  The steps above should help sort this out.
    Another option is to upgrade to a higher-performing extender.  That won't help if the issue isn't with the WiFi/Extender throughput.
  • StephenB's avatar
    Is the connection actually timing out, or are you just seeing a rise in ping times?
    A rise in ping time has two basic causes:
    • the ping packet is getting dropped by the extender or the router WiFi, and needs to be re-sent.
    • there is congestion on the network path (not necessarily wifi).
    The next time it rises, maybe try pinging from a machine that is connected by ethernet to the router.  There is a tool called pingplotter that could be useful (it is quite expensive, but you could just use it during the trial period).
      • StephenB's avatar
        mufcboy234 wrote:
        It rises.
