BenParkes's avatar
BenParkes
Netgear n300 ex2700 wifi extender says password is incorrect
Hello
Basically my router says "incorrect password" even though it is definitely correct. So I factory reset the router, reconnect to the router using the WPS button and it works again. Then after about a week it will start saying incorrect password even though it is definitely correct. The firmware is update. Does anyone have any suggestions? Thanks in advance.
