Trippy86's avatar
Dec 15, 2016
Netgear Nighthawk EX7000 connection issues
Hi
ive had the EX7000 for about a month and have had a few issues with devices connection
Firstly i have two nas drives connected directly to the EX7000, a WDmirror and a WDmycloud. If my laptop is connected to the EX7000 wifi i cannot access the hard drives on the mapped drives in windows explorer (im on windows 10). If i connect to the main virign media router downstairs i can access the fine and i cannot understand why?
Secondly when trying to connect to the EX7000 wifi 2G or 5G it can take an age to connect even when im right next to it, i can connect to the router downstairs almost instantly.
Does anyone have any ideas why this could be and know of any way i can resolve these issues?
Thanks a lot for your help
Trippy
  • Can anyone help? i would love to get it solved asap
    thanks so much
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello trippy86
      are you using the latest firmware on the ex7000?
      DarrenM
      • Trippy86's avatar
        Trippy86
        Tutor
        hi yes its the latest
        • Hardware Version: EX7000
        • Firmware Version: V1.0.0.50_1.0.102
        Connection to Existing Network (2.4GHz)
        • Signal Strength: 130 Mbps
        • Name (SSID): VM******-2G
        • Connection Status: Connected
        Connection to Existing Network (5GHz)
        • Signal Strength: 450 Mbps
        • Name (SSID): VM******-5G
        Extender WiFi Status (2.4GHz)
        • Name (SSID): VM******-2G_2GEXT
        • Region: Europe
        • Channel: Auto (11)
        • Wireless mode: Up to 600 Mbps
        • Wireless AP: On
        • Broadcast Name: On
        • Wi-Fi Protected Setup: Configured
        Extender WiFi Status (5GHz)
        • Name (SSID): VM******-5G_5GEXT
        • Region: Europe
        • Channel: 36 + 40 + 44(P) + 48
        • Wireless mode: Up to 1300 Mbps
        • Wireless AP: On
