rustygearhead
Dec 08, 2015Guide
Netgear PR2000 Trek N300 - as range extender: WiFi VERY slow / wired connection fast
I'm using my Netgear PR2000 Trek N300 as a range extender and when I connect to the LAN-only (yellow) port as wired connection with my laptop I get speeds of ~10Mb, however when I connect via ...
- Dec 17, 2015
Hello rustygearhead
Since only one wireless device can transmit at once, wireless transmissions are doubled (router to repeater and then repeater to client versus just router to client), and so Wireless throughput is reduced by at least 50%.
DarrenM
rustygearhead
Dec 16, 2015Guide
something very odd is going on................
I have my unit in repeater mode .... sorry if i did not mention that ....
I think that is why I can not change the channel on the unit.
I re-flashed the xx.14 firmware into the unit and did a hard reset and then set it backup with correct profile (which had been lost of course)
with the WIRED connection I get 15mb down and 6mb up
with the wireless connection I only get about 7mb down and 6mb up
I tested the wireless speed on both my laptop and iPhone 5s
so download speed is roughly cut in half with wireless connection and it does not appear the problem is related to the device since it tests with same speed on multiple devices....
DarrenM
Dec 17, 2015Sr. NETGEAR Moderator
Hello rustygearhead
DarrenM
- rustygearheadDec 17, 2015Guide
Darren:
Thank you ... that makes sense ... well I think it makes sense ....
There are now two wireless hops and the PR2000 is setup such that both hops are are on the same channel ...
It would seem throughput would be better if the repeater could be set to be on a different channel .... ???
As an experiment I may plug a wifi router into the LAN port of the PR2000 set it to a different channel and test wireless throughput that way....
What results would you expect to see from such a setup given that the wifi channel is good up to 54Mbps+ and my is only 15Mbps ???
Thanks!
Jim
- DarrenMDec 17, 2015Sr. NETGEAR Moderator
Rustygearhead
If you have the PR2000 plugged in via ethernet to your router you should be getting full speeds over the wifi.
DarrenM
- rustygearheadDec 23, 2015Guide
Darren:
Thanks for your help!
Here is my setup:
Main house---------------------------------------------------------->Workshop
Netgear SB6141 Router wnr2000v3 NetGear Trek N300 (Model PR2000)
hard-wired to cable modem Set in window facing main house
Speed: typically ~17Mb wired OR wireless NO WIRED connection to main house but has
an "almost" line-of-sight to Sb6141 in main house to pick up the "primary" WiFi signal
Speed: using yelllow LAN port (wired): 12Mb
Speed: using N300 Wifi - alas only : 6Mb
I think I understand that the "repeated" WiFi connection is why I see 12Mb wired vs. only 6Mb wireless in the workshop.
If I took another wifi router and plugged it into the LAN port of the N300 and set it to use a non-conflicting wifi channel I would think that I would then be able to take advantage of the "full" 12Mb that is available at the LAN port of the N300 over Wifi in the workshop rather than only having 6Mb of bandwidth?
Would that work? Did I miss something here?
Thanks,
Jim
