adamkkool
May 29, 2018Follower
Netgear R8000 Nighthawk X6 AC3200 Tri-Band Wifi Router not connecting with N300 wifi range extender
I recently just bought a N300, Model EX2700 range extender but it for some reason does not connect to my router. I am using a Netgear R8000 Nighthawk X6 AC3200 Tri-Band. WPS connection does not work,...
DarrenM
May 30, 2018Sr. NETGEAR Moderator
Have you tried to manually update the firmware on the ex2700? You may also want to try and change the SSID on the router to test if the extender can see the new name.
DarrenM
