Lozzie
Jan 12, 2019Follower
Netgear Wi fi extender EX3110
I have connected my wifi extender to my router but when I try to connect to my network with _2G EXT or _5G EXT using the network key, it won’t connect and says that it is incorrect. Any suggestions what to do next?
- Christian_RNETGEAR Employee Retired
Hi Lozzie,
If you log into the extender's user interface, you'll be able to see the network security for both bands. Please refer to the following article:
https://kb.netgear.com/000037341/How-to-find-the-Extender-WiFi-network-password
~Christian
- seemookAspirant
Hey,
Im having the same problem, cant login into _ext2 or _ext 5 with router password as it says it is incorrect.
Extender says its connected to router but wont connect to my device as i cant pass the WPA2 security (should be router password) so i am unable to get into the extenders settings.
What do i do?
Hi seemook,
Thanks for reaching out. Have you gotten a chance to check the article I linked earlier in the thread. If not, please perform the following steps and let me know the outcome.
~Christian
