Alfiemama
Jun 28, 2018Aspirant
Netgear wifi extender wn3000rpv3 - completely lost
I bought the Netgear extender a while ago - to be honest I couldn't get it to work and became so frustrated I gave up.
My daft husband tried to set it up and failed - and now can't remember passwo...
DarrenM
Jun 29, 2018Sr. NETGEAR Moderator
when factory resetting the device make sure to hold the reset button for 10+ seconds this should clear any old settings. But if you are seeing it as a network you may want to try the password as your main router and see if that works.
DarrenM
Alfiemama
Jun 30, 2018Aspirant
Thanks Darren, sorry for the delay, I will try that now
