terryclancy
Feb 09, 2014Follower
Netgear Wireless N150 Access Point WN604 Losing / Forgetting Settings after Reboot
I have a NETGEAR Wireless N150 Access Point WN604 which is losing / Forgetting Settings after Reboot or power cycle. It loses among other things the following settings: • Access Point Name • NTP...
ScubaClaude
Apr 23, 2014Aspirant
I had the same problem with two units but found a workaround. I've found the problem to be with the Netgear Registration box so you need to get this to reappear.
Connect to the unit using a wired connection, not wifi.
Take a backup of the config and reboot AP. Just reboot don't factory reset!
Log on to the AP and restore the config, wait for the unit to reboot.
Log on to the AP and this time the Netgear Registration box will appear
### IMPORTANT BIT ###
Only ever click "Remind Me Later" and the AP works fine. Click anything else and the settings get "locked"
My units have been working fine since I discovered this
Good luck
Good luck
- filicajaOct 21, 2015Aspirant
I had the same problem. I did what ScubaClaude suggested but it didn't work. Eventually I restored the factory settings of the AP.
Now it is working fine :-)
Antonio.
- JohnRoOct 21, 2015NETGEAR Employee Retired
Hi filicaja,
Welcome to the community!
Thank you for your contribution, I belive this issue may have been fixed by using the newer firmwares. You can download latest versions here.
Thanks,
- HiballerDec 05, 2015Aspirant
I have the same problem also.
The most annoying reversion/loss is that of the Primary DNS Server. It keeps reverting to 192.168.1.1 and keep having to change that to 192.168.1.254 to accomodate my UVerse router/modem. Until that is done, the AP is horribly sluggish and may take as long as 2 minutes to display a page.
The wireless AP broadcast name keeps resetting to one I used a few years ago and WILL NOT ratain a newer name I've given it. Along with this, the registration keeps popping up and greying out all the choices until I hit one of the buttons. I have registered this AP at least 10 times, yet this registration request keeps popping up every time I access the equipment.
I have downloaded and tried the firmware update offered by JohnRo, but this didn't seem to help. I am now at 3.3.1, but I see there is a newer version of 3.3.2. Will that help?:
Bill
