jamboe's avatar
jamboe
Novice
Feb 23, 2015
Netgear wn3000rp-200uks
Hi
I'm not very technical so please bear with me!
I've connected my extender to my router using WPS, so far so good. Unfortunately when I try to connect my iphone or any other device to the extender it says the passkey is invalid. The instructions say use the same passkey as for the router but it will not work. Any suggestions? Thanks!
1 Reply
  • Hi
    I am having exactly the same problem, I have plusnet and have reset the router to factory settings and i still cant connect to the extender as it doesn't recognise the password.:mad:
