spleenlessdemas
Jul 17, 2015Aspirant
Network interference error on Samsung Smart TV
I have a Samsung Smart TV and I'm trying to use my applications (Netflix, HBO Go, etc.), however, when I select them with my Samsung remote I get an error that says something like "Cannot complete du...
scruz007
Sep 18, 2015Aspirant
I'm experiencing the same issues.... except I'm not advanced and have no idea where my router settings are. It doesn't come up online. is it on the actual hardware or my TV? I have a samsung 7000 model.
thanks!
nhann
Sep 21, 2015NETGEAR Employee Retired
Hi scruz007,
Which NETGEAR router product are you using?
You can connect your computer to the router's WiFi.
Open up an internet browser, then login to routerlogin.net (or enter in your browser: 192.168.1.1 or 192.168.0.1).
Then please proceed with the steps described above
