jqcastelli
May 04, 2017Luminary
Nighthawk AC1900 does not play well with Arlo Netgear Base Station
Wifi internet router is a Netgear DGND3700v2 and my Arlo Base Station is hard wired thru CAT5 to it. I just purchased a Netgear Nighthawk AC1900 Wifi Range Extender to extend the range of the Arlo cam...
- May 10, 2017
That will not work you can use the extender by plugging the base into the Ethernet port no way to boost the dedicated arlo wifi singal off the base station.
DarrenM
DarrenM
May 10, 2017Sr. NETGEAR Moderator
Hello jqcastelli
What issues are happening when you connected the extender are you getting internet but the base station is not working?
DarrenM
- jqcastelliMay 10, 2017Luminary
Extender does not see the base station as a valid wifi network to tie into. I want to extend the range of my arlo camera as the base station is hardwired to the DSL Router. What do i have to do to hook up the extender to the base station and then the cameras to the extender?
- DarrenMMay 10, 2017Sr. NETGEAR Moderator
Are you connecting the base station via Ethernet to the extender?
DarrenM
NO I am not. I was tring to link via Wifi.
