jqcastelli
May 04, 2017Luminary
Nighthawk AC1900 does not play well with Arlo Netgear Base Station
Wifi internet router is a Netgear DGND3700v2 and my Arlo Base Station is hard wired thru CAT5 to it. I just purchased a Netgear Nighthawk AC1900 Wifi Range Extender to extend the range of the Arlo cam...
- May 10, 2017
That will not work you can use the extender by plugging the base into the Ethernet port no way to boost the dedicated arlo wifi singal off the base station.
DarrenM
jqcastelli
May 10, 2017Luminary
NO I am not. I was tring to link via Wifi.
DarrenM
May 10, 2017Sr. NETGEAR Moderator
DarrenM
