Confused12345
Oct 09, 2024Aspirant
Nighthawk EAX80 not connecting with Nighthawk RS700s
I’m trying to add an EAX80 to my router to allow the whole house to be covered. However, I can’t add the extender via the app and only via the WPS. When I use the app I can’t see the extender and also...
Oct 09, 2024Guru - Experienced User
Try connecting a wired PC to the back of the EAX80 and set it up using a PC and web browser. I was able to get my EAX80 to connect to my RS600 using this method. There is a setup wizard process when using a PC and web browser. Should work for you. No WPS needed.
