RichardB56
Jul 08, 2024Apprentice
NIGHTHAWK EX7000 AC1900 WI-FI RANGE EXTENDER WON'T CONNECT TO NIGHTHAWK APP
The Nighthawk app sees my SSID from the Nighthawk Ex7000 Ac1900 Wi-Fi Range Extender but will not connect. The range extender is working properly, devices are connected and operating but the Nightha...
Jul 08, 2024Guru - Experienced User
So it works fine other than the app not working?
Can you log in through the browser?
RichardB56
Jul 09, 2024Apprentice
Yes. The web browser access works fine. The App will not connect. I just get a blank screen. I know this is not crucial since I have web access. Just trying to get it to work.
- plemansJul 09, 2024Guru - Experienced User
have you tried a different device?
Clearing cache/data on the app?
- RichardB56Jul 10, 2024Apprentice
Only have the one device. I cleared the cache and started from scratch. It appears to need to complete set up with a different SSID then what I already have configured. It sees my SSID but will not log in.
