DavidSD's avatar
DavidSD
Nighthawk R6700 - add access point
I have issues with WiFi signal strength in my daughters room. I have tried extending the signal with a AC1200 extender but it did not help. Her laptop will only handle the 2.4 range. I was wondering about using either the Netgear AC1200 or her ARRIS SURFboard SBG6782-AC Cable Modem and AC1750 Wi-Fi Router as an access point to improve the 2.4 signal for her. Can I use either or both of thee devices as APs? If so, which would be better and how would I do it? I have an available LAN port on my R6700 so I can run an ethernet cable to her room. Or is there a better extender to use? Any help and guidance would be appreciated.
  • You didn't specify your range extender's model.  Most Netgear range extenders can be used as an Access Point, except for a few models.
    All routers can be used can be used as an Access Point as well.  The R6700 can be placed into AP Mode under ADVANCED > Advanced Setup > Wireless AP.  Follow the onscreen instructions.  They should be self-explanatory.
