Swindonpete
Nov 29, 2020Guide
Nighthawk Wi-Fi extender and Ring camera live view
Hi I have a Ring camera and a Nighthawk extender but I can't get a live view on my Ring app although the Ring app shows the camera as connected with RSSI c-55 and the motion sensor lights trigger on motion and the Ring app alerts us to motion detected etc. Can anyone help me sort out how to fix the not able to show live view issue. I have a iPhone 11 with latest IOS and also a iPadPro again up,to date IOS. Any ideas ' help,appreciated please. Thanks in advance.
Does it work if you're directly connected to your router with the ring device?
Are any other devices having issues?
Firmware on the extender?
Did it work before with the extender?
What router are you using?
What method of instal for the extender did you use? the installation assistant or using WPS.
I'm just trying to figure out why you think the extender is the issue.
- Thanks for the quick reply. I will have a look at a couple of your points in the morning here (UK) and answer the others too. Thank you again. I’ll get back to you tomorrow.
Hi again,
No other ring devices have any problems but are connected to my BT router. The camera in the garden got v poor signal and would not work so I bought the Netgear. I set it up not using WPS as advised by others when I looked into it. I connected my camera via Wi-Fi (which I brought into the house) to my BT router this morning and live view works fine but it didn't when connected to the netgear? Is there a setting on th emerge are I need to change or? Thanks again for your help with this issue.
- Me365Aspirant
Hello Swindonpete ,
I'm late in replying to your question . I hope you got it worked out. I spent 5 hours on the phone yesterday with Ring Tech support and they could not figure out why I couldn't get Live View to work. My installation was done by an electrical engineer, so I had to insist that it was not an installer error.
Ring Tech support knows my devices are connected to my Guest network, properly secured with a complex password, and isolated from my LAN and other devices.
We went over my firewall and router settings. At no time did they ask me whether Remote Administration of Firewall was enabled.
This morning, I inspected my router logs from the Admin console. I have many entries for Service Blocked: Remote Administration of Firewall.
I don't have this option enabled for security. I am reading about whether this can be enabled safely, internal/external IP addresses and ports to choose. I am also reading about the ports and protocols used by Ring Devices, and whether Port Forwarding is an option.
The Protocols and Ports Used by Ring Devices – Ring Help
According to this article from the SANS institute, Port 6970 is a port widely abused by trojans.
Port 6970 (tcp/udp) Attack Activity (sans.edu)
I just wanted to give you this information in case it might help you with your issue as well. This has been absolutely maddening!
