tz10uk
Nov 03, 2018Aspirant
Nighthawk X10 Create a mesh with the same SSID with 2 EX8000
Hi
I have a R9000 (5D82855V003DB) router running off a Virgin Media router set as a modem, this router has a SSID as wifi is a real issue in my house and power lines dont work, I purchase 2 EX...
- Nov 08, 2018
tz10uk wrote:
do you recomend a channel for the 2 GHz I have multiple other routers so clashing
There are some apps out there that can look for interference, and help you select a reasonable channel.
But you could just set it to use the channel it's selected now.
You might also try setting the 5 Ghz channel to the highest channel number on the list, and see if that is more stable.
Nov 04, 2018Guru - Experienced User
Is it stable with only one EX8000?
- tz10ukNov 08, 2018Aspirant
Hi thanks for your reply
No it drops out just very odd
T
- StephenBNov 08, 2018Guru - Experienced User
What firmware is running in the EX8000s?
Are the R9000 radios set to "auto"? If so, perhaps try setting them to fixed channels.
Hi
Thanks for your reply the software is the latest as it did an update when I set it up (but ill login and see what it is) 2Ghz is set to auto but the 5Ghz is set to 44
do you recomend a channel for the 2 GHz I have multiple other routers so clashing can be an issue to
Thanks
T
