tz10uk's avatar
tz10uk
Nighthawk X10 Create a mesh with the same SSID with 2 EX8000
Hi    I have a R9000 (5D82855V003DB) router running off a Virgin Media router set as a modem, this router has a SSID as wifi is a real issue in my house and power lines dont work, I purchase 2 EX...
  • StephenB's avatar
    Nov 08, 2018
    tz10uk wrote:
    do you recomend a channel for the 2 GHz I have multiple other routers so clashing
    There are some apps out there that can look for interference, and help you select a reasonable channel.
    But you could just set it to use the channel it's selected now.
    You might also try setting the 5 Ghz channel to the highest channel number on the list, and see if that is more stable.
