Buddy3's avatar
Buddy3
Follower
Mar 30, 2018
Nighthawk X4s Tri-Band Extender. EX7500
new Nighthawk is does not power up.  Unit remains in constant blue-blink power status.  Tried reset button, did not fix.  Tried power down, no fix.
1 Reply
  • Hi Buddy3,
                         Try to do reset for 1 minute when the unit is turned on to see if that helps. If it doesn't, try to do ON/OFF reset and see if that works.
