Sarah_louise's avatar
Sarah_louise
Nighthawk X6 extender question - can you use two?
Hi,
I’m using a Nighthawk X6 extender to extend the wifi in my house, but I need to extend it further. My router is at one end of the house and then the current extender is in the middle of the house, and then I need to extend the wifi to the other end of the house. Will it work if I buy another identical Nighthawk X6 extender?
Thank you in advance!
EX7700 — AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
  • plemans's avatar
    Can you do it? Yes.
    But what I'd do is try to move the router.
    Go
    extender<-------router------->extender
    Try to move the router to the middle with the extenders setup with a star configuration and not daisy chained. It'll be more stable. Otherwise, you can end up with the extenders connecting to each other if the router's signal drops or has any issues.
    • Retired_Member's avatar
      Retired_Member
      plemans Except these Mesh Extenders are actually designed specifically to be able to daisy chain and go extender to extender like a typical "mesh" system...
      • plemans's avatar
        Glad you corrected me. I'm happy to learn that I've wasted years of time on here helping out and being proficient with extenders.
    • Sarah_louise's avatar
      Sarah_louise
      Thanks very much for your advice. I don’t think I can move the router though. It has to be plugged in to the broadband socket, which is in a specific room at the end of the house
        Retired_Member
        Sarah_louise Do you have broadband port in more than one room in the house?
        When we bought our house, the modem had been connected in the Kitchen on the main floor.  I had a connection in the bedroom on the second floor.  So I put my modem and router up there, so wifi started out on the second floor for better coverage.  Feel free to check if you can connect your modem in more than one room in your home for better coverage.
  • FURRYe38's avatar
    Yes.
    What is the distance between the router and extender(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
      Sarah_louise
      Ok thanks. The house is 80 feet long and the router is at one end.
