Detritus2uk's avatar
Detritus2uk
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing .
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing . Wired connections work but wifi does not. Have tried factory reset (rest 7 seconds) but not change. Can anybody advise. Is there are hard reset ?
  • plemans's avatar
    But the wired connections to it work fine?
    Have you tried going through the setup while hardwired into it?
    • Detritus2uk's avatar
      Detritus2uk
      The wired connections can talk to each other but and the internet provided one of the connections is a wired connection to the router but the management website will not connect and the AP does not show as connected or get an IP address .
