KFischer's avatar
KFischer
No connection to router
Got a new router from O2 last week. Since then my repeater can't find the homenetwork any more. I tried reset to factory settings and direct connection via WPS button as well as via browser following the instructions on the Netgear website. Both did not work.
Any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello KFIscher
    Make sure when doing the factory reset you are holding the button for 10 seconds.
    DarrenM
    • KFischer's avatar
      KFischer
      Hello DarrenM,
      I did as you said. The power supply LED on the repeater turned orange and then green again after a while. I the pressed the WPS buttons bothe on the repeater and my router until the WPS-LED's on both devices started blinking in regular intervals. After about a minute the LED on the repeater stopped blinking, but the WLAN connection LED on the repeater in the top roght corner of the device remained dark throughout, i.e. no connection.
