Davee3
Mar 15, 2015Aspirant
No entries in Attached devices wndr3700
Log in ok using main network ( or guest network) on wired connection When I go to" Attached devices" nothing shows up as entries What would prevent this?:confused:
Davee3
Mar 20, 2015Aspirant
searay wrote: If this option is important to you I would consider a different router. I had same problem over 5 years ago and if they were going address it I think they would had by now.
2 Wndr3700V1
1 Wndr3700AV
This was a joke back then when they played the game of rebranding a lemon.
Thanks _ I am trying to set up a surveillance system access through internet & think I need specific address info on the device connected to the router etc
The instructions for a peer to peer network are as clear as mud to me:mad::o
I can get the pictures locally on wifi connection from the router
