WizzKidDV
Oct 05, 2013Aspirant
NO INTERNET ACCESS but Connected to EXTENDER
Hello all, I am an IT Guy having issues with a Customer's Wireless Network. I recently implemented the WN2500RP and things were good for a few days. Then I got complaints that that Laptops and IPa...
Bthomson
Oct 17, 2013Aspirant
WizzKidDV wrote: I understand what you are saying. And I do appreciate your guidance JMizoguchi.
But that is not a viable solution by any means. It's like a Car Tire loosing air and the solution is to keep filling air everyday because we don't know where the hole is in the tire.
There is a perfectly good solution. Replace the damn thing. And so I did.
Installed an EnGenius EAP300 Access Point on Monday and (knock on wood) haven't had any hick-ups since. As an AP it does require a Hard Line. But stability is key for any Network Operation. Not to mention wider range and SAME COST of around $90!
Sorry Netgear, BALL DROPPED!
I'm having similar issues as you did WizzkidDv. Did changing out the wn2500rp solve the problem?
