Lakers23206
Apr 15, 2020Initiate
No internet connection through wired connection from ac750 WiFi extender
I’m having issues connecting through wired connection from the WiFi extender, it was working fine and connected with not issues through a wired connection from the extender to the pc but since my router has been turned off and back on again it won’t connect through a wired connection from the extender, i have tried on both a laptop and desktop but still says it’s connected to the extender but has no internet connection. The extender will connect wirelessly to the laptop with no issues. I have factory reset the extender also. Any help would be appreciated
Have you reset the router? From the sounds of it, the router turning on/off was the initial cause. Maybe it corrupted something in the router
- Lakers23206InitiateFIXED: all working again, I did reset the router last night after it was first turned off and back on but I have tried again and it seems to be fine, though a simple one I’m glad I posted!
Thank you for your help.
