Winco
Jan 05, 2019Tutor
ORBI RBS50Y-EXT not showing as a satellite in the network map
Hello all,
I have just purchased an Orbi RBR50 with matching satellite. I decided to add to this set-up by purchasing an Orbi RBS50Y-EXT outdoor extender to increase our coverage.
I set i...
Jan 09, 2019Guru - Experienced User
What firmware are you running in the RBR50?
It should appear in the satellite list, but I have seen satellites show up as devices from time to time in the router UI. You can access the satellite directly by browsing to it's IP address and that will show you if it is connected to the Orbi backhaul.
You could also try powering down the new satellite, rebooting your orbi system, and then powering it up again. That might result in the router putting the satellite in the right place.
- WincoJan 09, 2019Tutor
Thanks Stephen for the reply. I'm using the latest firmware.
I'll try your suggestion and report back.
Actually before I attempt to access the satellite directly by browsing to it's IP address, I should ask how do I do this?
- Christian_RJan 10, 2019NETGEAR Employee Retired
Hello Winco - You can view the satellite's IP address by logging into the router's UI and taking a look at the satellite list for the IP address of the respective satellite.
~Christian
- StephenBJan 10, 2019Guru - Experienced User
~Christian
Of course in your case it's the IP address in the attached device list.
Then enter http://xxx.xxx.xxx.xxx in your browser (using the real IP address instead of the xxx's). The password should match the one set on your router.
